AweSun Cloud KVM Q1
Smarter Plug-and-Play Remote Control Solution
Tired of complicated remote setups, driver hassles, and unreliable access?
Q1 is here to change the game — a compact, smart, and versatile remote control device that simplifies IT management, remote work, and troubleshooting.
Meet AweSun Q1: Compact, Powerful, and Hassle-Free Remote Control
BIOS-level remote control with no software install. Replace IPKVM complexity with AweSun Cloud KVM Q1. No software installation required on the controlled device. No system restrictions. Just plug, bind, and control — anywhere, anytime.
✅ BIOS-level IPKVM access
✅ No software or OS dependency
✅ Offline Remote Access from mobile or PC
✅ Plug-and-play setup with simple cable connections
✅ Supports PC, Mac, industrial systems, phones, tablets
Why choose AweSun Q1?
Full Cloud Control – Easy Device Management
Manage multiple computers or servers from a single cloud dashboard. No matter where you are, access and operate your devices instantly.
No Drivers, No Fuss - Just Plug and Play
Forget about installation and compatibility issues. Q1 supports remote control of devices running Windows, macOS, Linux, iOS, and Android. No software installation required on the controlled device.
BIOS-Level Control - Even if the system crashes
Unlike standard remote tools, Q1 gives you full control from boot to desktop, including BIOS access. Remotely fix blue screens, reboot systems, and recover from crashes.
Extremely Compact — Ultra-Compact Size, Saving Space
The Q1 is smaller than a credit card and can be seamlessly integrated into IT racks, workstations, or travel kit without bulky hardware.
Screen Off, Power On - Control Your Devices Effortlessly
With broad compatibility, Q1 supports remote control of desktops, laptops, tablets, smartphones, servers, and NVRs — even when the screen is off.
Watchdog Protection - Regardless of the Situation
Q1 automatically recovers from system failures, keeping your devices accessible and minimizing downtime.
Who needs AweSun Q1?
IT Administrators / Data Center Managers
IT personnel can use AweSun Q1 with a KVM switch to remotely manage multiple servers. Even in the event of a system crash, BIOS-level access is supported. AweSun Q1 enables browser-based remote access without requiring a public IP, providing efficient, stable, and secure enterprise-grade remote management.
Software Development Teams
Developers can securely access in-office computers remotely — even without public internet or while working off-site. With the controlled device connected to the Internet, AweSun Q1 enables secure code debugging and issue resolution — all while keeping your data safely within the local network through enterprise-level encryption.
Security-Conscious Professionals
Designed for industries with strict data confidentiality requirements—such as finance, healthcare, and law—AweSun Q1 supports secure LAN-based remote access without an internet connection. It prevents data leaks and cyberattacks, providing a high-security remote control environment.
How It Works:
1️⃣ Bind Your Q1
Connect Q1 to power and Ethernet.
Install the AweSun App on your phone.
Add Q1, set a name and access password.
2️⃣ Connect Your Target Device
Plug your device’s USB and HDMI into Q1.
In the app, select Q1. If both indicators are green, you’re connected.
Enter your password to access remotely, even to BIOS.
Q1 Connection Guide - Connecting Q1 to the Target Device
Note:
⚠️ To remotely control your phone, a docking station is required. Please note that the docking station is not part of this package and needs to be acquired separately.
⚠️ iPhone requires iOS 16 or later; Android phones require Android 12 or later.
⚠️ Not supported: Redmi, Huawei Nova series, and iQOO phones.
⚠️ Phone-to-phone remote control is currently not supported. Please stay tuned for future OTA updates.
Verified Phone/Tablet Compatibility List
i0S:
Android :
Technical Specification
Package Contents
1 × AweSun Q1 KVM
1 × Power Adapter
Q1 User Manual
User Manual Link: https://service.oray.com/en/question/46943.html
Shipping Timeline
We’re currently on track to begin shipping AweSun Q1 KVM units by November 2025. Orders will be shipped in batches based on your backer number and region.
