Skip to product information
1 of 8
AweSeed
AweSeed R300A Industrial Router 4G LTE Router Broadband Wireless WIFI Supports SIM Card wifi Router Network SD-WAN NAT Traversal
Regular price €96,95 EUR
Regular price Sale price €96,95 EUR
Sale Sold out
Model
【Reliable High-Gain Connectivity】Stronger and more stable wireless performance with high-gain antennas and switchable wired/wireless options, ensuring uninterrupted operations in any environment.
【Seamless Remote Networking】Layer 2 networking enables remote PLC operation, real-time monitoring, and industrial data aggregation—without IP reconfiguration or costly on-site visits.
【Always-On Performance with Redundancy】Automatic failover instantly switches to a backup router if the primary connection fails, while the smart watchdog ensures self-recovery from disconnections to minimize downtime.
【Centralized Management & Monitoring】Auto-discovery makes it easy to remotely manage, monitor, and troubleshoot all devices from a single dashboard, saving time and simplifying operations.
【Built for Harsh Industrial Environments】Industrial-grade sheet metal casing, extended temperature tolerance (-20°C to 70°C), and superior heat dissipation deliver long-term durability and stability in extreme conditions.
View full details
AweSeed R300A
Product Name 4G LTE Industrial Cellular Router with Dual SIM Slots, RS485, and DIN-Rail Mount for IoT/IIoT Smart Manufacturing Solutions
Application Industrial loT/Surveillance Camera Management/Remote Maintenance/Unmanned Oil Well/Unmanned Pump Room/Unmanned Electric Machine Room/Supermarket Surveillance/Smart Parcel Locker/Vending Machine
Model Number R300A-EL
Material Metal
Capacity ROM 128MB + Flash 16MB
Ethernet Port 100Mbps Ethernet WAN/LAN Port * 1
100Mbps Ethernet LAN Port * 4
Antennas Detachable external WiFi antenna*1
Detachable external 4G antenna*1
Antenna Gain Wi-Fi antenna 3dBi; 4G antenna 3dBi
Networking Protocol  CSMA/CA, CSMA/CD, TCP/IP, DHCP, ICMP
NAT, PPPoE, etc
Network Standard  WiFi Protocol: IEEE 802.11 b/g/n
Wired Protocol: IEEE 802.3. IEEE 802.3u, etc
Cellular Frequency Band LTE FDD: B1,83,B5,B7,B8,B20,B28
LTE TDD: B38,840,B41
WCDMA: B1,85,B8
Indicator Light SYS (RGB LED)
WIFI (WiFi Indicator Light)
4G (Level-3 Cellular Signal Indicator)
Networking Protocol CSMA/CA, CSMA/CD, TCP/IP, DHCP, ICMP NAT, PPPoE, etc
Dimension
(Antenna not included)
111 x 94 x 28mm (4.37*3.7*1.linch)|
Working humidity&Temperature 20-70°C 10%-90% RH (non-condensing)
Storage humidity&Temperature -40-85°C 5%-90%RH (non-condensing)
Power Supply 2 Pin 5.08mm pluggable industrial terminal (CN Version)
Power Input Width voltage DC5-36V, standard DC power 12V/1.0A
Installation Methods DIN rail mounting, Screw mounting, Wall-mounting
Specification
AweSeed R300A SDWAN VPN Cellular Router
5 Ethernet Ports: 5 WAN / LAN Port support more end-devicesconnect via wired. Metal Outer shell: excellent heat dissipation.
Router Industrial-Grade Design
Engineered for the harsh outdoor & industrialUncompromising Durability in Mining & Industrial Environments.
Features:
* Support Panel or Din-Rail Install
* Lightning Protection Port
* IP30 Protection Rate
* Reverse Polarity Protechtion Surge & ESD
Surge Protection & Electrostatic Discharge (ESD) Protection
R300A equipped with advanced ESD and surge protection, effectively preventing damage your device from electrostatic discharge and power surges. It ensures stable performance even during power
fluctuations or external interference, improving system reliability, security, and extending the device’s lifespan.
NO NEED Dedicated Line & Public IP - Intelligent Networking
Break geographical barrier, enalble remote networking access and file transfer.
Support centralized manage via Cloud platform, provide screen dashboard to track device connections in real time and send timely alert notifications. Remote troubleshooting and maintenance, NO need on-site personnel
Remote manage video surveillance access region
* Centrally manage multiple remote monitoring CCTV Camera;
* Centralized Video Surveillance Storage;
* Remote Access & Playback CCTV Video;
* Remote Configuration of Surveillance Devices;
Support: Live Video, Video Playback, E-Map, Video Dashboard.
Apply for Public Security Surveillance, Chain Store Surveillance and Outdoor Surveillance.
Support centralized viewing & manage cameras online from over 90% brands of market, including Hikvision, Dahua, Tiandy, Unisinsight, Kedacom, TP-Link, Uniview, Xiaomi and more.
AweSeed in-house CloudVPN Technology
Professional Solutions For Complex Networking Challenges Across Diverse Scenarios;
Build Better and More Secure Connections.
Cloud Configuration
Support Bulk configuration, Remote Management, Centralized Monitor.
Solution Advantage
Based on a layer-2 direct connection network, enabling remote LLDP & PNDCP, data collection and remote maintenance of PLC devices - NO on-sitepersonnel required.
Features:
*OSI Layer 2 directly connect;
*Monitor Dashboard;
*Primary and backup router switching;
*Alert Notification;
*Data Collection
CCTV Camera Surveillance Video Solution:
Remotely transmit surveillance video from multiple sites, simplify deployment and
management — no technical staff needed on-site.
Smart parcel locker & Vending machine wireless transmission solution:
24/7 real-time monitoring & data transmission — Reduce logistics costs, improve serve efficiency.
Application
Solution Advantage
AweSeed R300 Series Industrial Router can provide network to offline devices, easy to deploy, support centralized and remote
management, no need on-site personnel, reduce maintenance cost and improve operation efficiency.
Features:
* Built-in SIM card (availeble in CN version)
* Data Traffic Management
* Centralize Manage Devices
* Smart Deployment
LED Indicator Light Status
Ports
Packing & Delivery
Packing List
Industrial 4G LTE SD-WAN Router R300A
 * 1
DIN35 hook clasp
(Installed with Router already)
 * 1
2PIN Terminal Blocks Connector
 * 1
Grounding Kit
(Round Washer Screws + Lug Terminals)
 * 1
Screws Kit
 * 2
User Guide
 * 1
The set version provide power supply and antenna
 * 1
